hi all
Having an issue with our hot water.
In our system we have a hot water cylinder and cold water tank. We are in a flat so the pressure isn't great from the tanks so there is a pump which increases the pressure on the hot water tap in the kitchen, the bath and bathroom sink mixer.
The issue is particularly obvious when showering - we set the desired temperature and will be fine but suddenly the hot water will stop and shower will go freezing - when this happens the pump sounds like it's struggling. Often turning off the hot tap and back on will instantly fix it - it's not consistent sometimes it will be fine for a shower and then others it will be a nightmare. its not just he shower - have the same problem when filling the bath although less obvious.
Anyone any ideas what could cause this?
Marc
Marc
