Hi Again,
I've had a new 22mm feed put into my new bath as the pressure was poor (probably because I'd run a 15mm feed - doh). On completing the work it did sohow somw minor improvement but nowhere near what was expected. The plumber has advised that the tap is a continental one which only has 10mm inlets which he says are designed for pressure systems - mine is gravity fed.
I could get a new tap with 15mm inlets which I want to try and avoid due to the cost but was wondering if there are any pumps on the market for this type of scenario i.e. a single feed in line pump - any advice on this would be good
Rhys
Rhys
