hello, ive replaced a radiator in the bathroom for a larger one, had to extend the pipe so joined a 15mm to a 8mm then to the radiator, also moved a sink and attached new taps,
i drained the system down to do all this, when i filled it again switched the boiler on, it fires up, clanks,bangs,clicks and whirs for a bit, sounds of water rushing through it, then it shuts down,
in the airing cupboard the feeder tank now has the hot water in it, overflow pipes adds it, steam the lot, no hot water at taps, water comes out but its cold, bleed every radiator, bleed all i could think of,
any ideas,
someone says i have air in the boiler, bled all i can think off,
make of boiler is Halstead Balmoral 55F
did i do wrong joining one size pipe to another???
any ideas,
