Go with the ACV they have fantastic reheat times. Only limited by how much heat from the boilers you can throw at it.
Is your water supply up to it?
Or alternatively a 600 litre ACV. Would this have a better performance than 2 x 300 litre cyls?
I would never fit a 250 li when a 300 li is more suitable.
No mention of the owner's hot water or for cooking and washing!
Tony
Would you consider hot water priority?
I know the ACV cylinders can absorb a significant amount of kW's (the SL320 can in fact take 70kW). There is a 60kW boiler going in, but in the height of winter when supplying LTHW heating there wouldn't be a huge amount left for the cylinders, perhaps around 5-10kW (although that is not uncommon and may not be an issue).
