First of all I apologise for scant details as the problem is in my sons house. I hope by relating what has taken place over the past couple of days will make sense to someone and come up with an answer. My son lives in a 4 in a block cottage style flat in Glasgow. I am unsure of his water system set up. For example in this type of house is there a header tanks. There is no close so it there was it would have to be in an attic and access would be gained vis the upstairs neigbours house ??
This is an ex corporation house so probably built in the 1940s.
He contatcted me 3 days ago and told me that the radiator in a bedroom was stone cold whilst all others were hot. He checked his boiler and the pressure was nil. He topped up the pressure and this radiator immediately heated up. Apart from this all the water has been running fine.
As he is doing up this bedroom he removed the radiator to replace it etc. All he did was close the inlet and outlet valves and removed the radiator. He tells me water was everywhere due to problems fully closing the valves but he managed to do this.
Since then the hot water in his bath, washhand basin and kitchen sink has run brown and smells. He has run it for a few hours and it is still brown.
I was at the house today and noticed one of the valves where the radiator was, was leaking due to a bent pipe, I replaced that with a new valve and the hot water initially ran clear but then became brown.
After removing the radiator he tells me his pressure was low so he topped up to 1 1 /2 . On turning on the CH this shot up to 3 and he is having trouble getting it back down.
Sorry for the long post but hope this make sense.
