Our Hot Water Tank appears to be dripping, as you'll see from atatched video (first link) and pictures (below).
http://img821.imageshack.us/img821/9326/ezvnbemnzwppjnkclauohq.mp4
A few queries:-
From the Technical Details label on the tank (picture 3), it states under point 5 that if
"Hot Water issues from the discharge pipe, switch off the heat source and consult the instructions (fault finding chart). If in doubt, switch off the heat source and contact a competent installer or an authorised Heatrae Sadia Service Engineer or Agent"
1. With regard to this, is the water that is dripping in the video actually in the "discharge pipe"?
2. If so, what are the implications of this?
3. Could this be what is causing a loss of pressure in our boiler (we had this serviced recently and engineer noticed boiler pressure was low, we told him the pressure often dropped below 1 bar every month or so.
The fourth picture below shows a switch for the tank, that is off and always has been off since we moved in.
4. What does this switch do and should it always remain off?
Two images below are pictures of tank.
photo upload
temp img uploader
Next image is picture of technical details of tank
upload pictures
Next image is picture of switch for tank
photo upload
A few queries:-
photo upload
temp img uploader
upload pictures
photo upload
