Sarahbee please answer following so I/ we can understand better whats going on
1)Is the arrow on the pump now pointing along the pipework towards the boiler flow connection as shown on the cylinder pic above
2) Could you tell me what other things there are between your pump and your flow connection on the cylinder.
I expect you to reply with one or more of the following:-
Diverter valve [box with a wire connected and 3 pipes going into it]
zone valve [box with a wire connected and 2 pipes going into it]
de-aerator [A thing with 4 pipes going into it]
By-Pass [A tee which leads to a valve that goes to the return pipe]
3)Have you tried altering your pump speed
and what speed is it set to?
4)What number is your boiler stat set to
What is the highest number you can set it to?
5) Is there a cylinder stat and what temp is that set to![Question :?: :?:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
i have turned the pump around
