I have just bought a pump to boost my shower and the fitting instructions say it must not be used with water over 60 degrees C. My problem is that my current hot water cylinder, which is worked off a Trianco TRO 15/19 boiler , does not have a thermostat . The water is always scalding. The Trianco allows me to have the hot water system on when the central heating is on but never the central heating on its own The boiler thermostat does not seem to control the hot water in the cylinder.
How do I sort this out; Do I fit a limpet thermostat to the cylinder and connect this to a motorised valve.? If so where is it wired to and where does the valve go.
Or do I fit a limpet thermostat to the cylinder and wire it into the Trianco?, If so where do the connections go?
Thanks very much for ANY advice.
Cheers
GPObantam
Cheers
GPObantam
