hot water too hot!!!!!!!!!!
5 Sep 2008
Hi
i just had a new central heating system installed with a worchester bosch 37cdi..
One thing i have noticed is that when the central heating system is running the tap water is extremely hot (scalding hot) and gradually cools to the set temp.
Is this normal.. this is my first combi boiler so I am unsure??
Are you saying that for about the first ten seconds of running the tap the water is very hot then settles down to normal temp it would get to with heating having not been on . Then yes this is normal on most combi`s
that's exactly what happens... just wasn't sure it was normal.
perfectly normal, if it bothers you turn down the boilerstat for the c/h and this will help a little.
