    Dismiss Notice
Worchester Bosch boiler automatically switches on to heat hot water
Discussion in 'Plumbing and Central Heating' started by 802595353, 25 Apr 2021.
  1. 802595353
    802595353
    28 May 2008
    20
    Thanks Received:
    Country:
    Hi, I have a Worchester Bosch 8000 Life, 35KW and I have noticed every evening at 18.10, the boiler automatically fires to heat the hot water. No hot water taps in the house have been turned on.
    Is there a timer in the boiler which programs this feature to happen
  2. Sponsored Links
  3. oldbutnotdead
    oldbutnotdead
    11 Jan 2013
    4,054
    Thanks Received:
    821
    Durham
    Country:
    Is this a combi boiler? If yes there is a setting that keeps water in the dhw hex warm- makes response to tap opening a bit quicker. Have a read of the manual for your model.
    Or. Does the boiler fire up fully or just make some whirring and chuckling noises? Again I think the thing is set to spin the pump and move a few other moving parts once every 24 hours (to prevent those parts from getting stiff thru underuse in the summer and failing in October).
  4. 802595353
    802595353
    28 May 2008
    20
    Thanks Received:
    Country:
    Thanks for your reply, it is a Combi boiler and I checked at 18.10 and the boiler switched on. I could hear water going in the boiler and the pump running but the boiler didn't fire up.
Loading...
Share This Page
