Hi - I'd really appreciate some help on an issue I'm having with my hot water.
It's a conventional boiler system (pretty old). Symptom is less hot water than before and I only really get good hot water in the cylinder when the HW and CW programmes have been running for a fair time. CH is OK. This is what I've observed:
1. 2way valve was replaced earlier in the year as HW stopped working but was OK after initial install
2. The top of the 2way valve does get quite warm/hot to touch - is this normal?
3. CH is OK - ie when on the boiler is firing continuously until room thermostat reaches setting. I have however noticed that if I just have the CH programme selected it does not fire the boiler and boiler only fires when HW is also turned on - so poss valve fault on the CH ? Not sure of the two issues coincide or a related as I generally have HW and CH on at the same time anyway.
4. I don't have a multi-meter at the mo but could poss get hold of one.
Thanks very much - your input would be much appreciated.
Regards
- Programmer on for HW - boiler fires OK, pump runs, 2way motorised valve appears to open OK (lever is loose/floppy - ie moves freely left and right)
- But after a minute or 2 the boiler stops
- Pump is still running, motorised valve lever is still loose
- After a while (several minutes) the boiler will fire again for a min or 2 and go off again
- Adjusting the cylinder thermostat higher or lower does not change the behaviour
- Therefore getting adequate hot water in the cylinder takes a long time
Regards
