Just as a background, I have for a number of years run my Heating continuously with Hot Water chipping in 3 times a day, and this has all worked fine. (Heating is controlled by a programmable stat.)
I now have an odd situation in that the Hot Water will not run if the Heating is on, which is a problem I had years ago when I did not have a HW Off signal.
I have changed the Head on the motorised 3-port valve, but still it will only run one or the other. (Never sits ion the middle).
The cylinder thermostat has been removed, and the wiring re-done. The stat seems to operate smoothly enough, and is not that old. Hot Water, once it has run is fine.
I have also checked the wiring in the programmer, and that all seems to be intact, except I don't seem to have a CH Off wire. The system has worked in the past, so not worried about that.
I think now, that the programmer maybe knackered. It is quite old. The programmer was also not located correctly on the back-plate meaning it could swing on the contacts and top hinge. The contacts look OK, and I have cleaned the pins with a contact cleaning 'rubber'. Still no joy.
Any ideas?
3-port valve is a Drayton MA1
Programmer is a Honeywell ST6400C
Cylinder Stat is a Danfoss AT
Thanks in anticipation
Any ideas?
