Hotpoint Aquaria 1000 WM62
18 Feb 2007
Yorkshire
The problem is when switched on will not start, however after a period of between 2~10 minutes will start and run as normall. Can anybody offer any help ?.
Sounds like the door switch is on it's way out. Simple enough to change (with machine unplugged) You can get access through the door seal aperture after removing the retaining wire and peeling back part of the door seal.
Thank you fido, I will get a door switch and post the results.
