Hotpoint Aquarius WD420P temperature too hot
22 Oct 2009
Hertfordshire
My Hotpoint Aquarius WD420P (washer/dryer) gets way hot during washing, the clothes come out steaming... It doesn't matter how I set the temperature, they all come out the same way. The hot dampness doesn't make my clothes any fresher!
Maybe needless to say but the built-in dryer has the same problem: clothes are steaming hot and damp instead of dry (or even relatively dry).
Could this be a filter/clogging problem? Is there anything I can have a look at myself?
Thanks for your help!
Syl
have a look at the water in hoses
are they cold to cold & hot to hot.
or if cold only then is it the cold tap ??
wf220 is not a washer dryer wrong model number.post back model number should be wd ....
Thanks!
and oops, I just used the number it said on the front of the machine...
Apparently it's actually a WD420P.
I will check the board again if there's anything already posted, but do reply if you have any ideas!
depending on the serial number it could be hot and cold or cold only,setting the temp does not set the temp thats for hand wash only .when you put it on 40 thats the temp it washes at same as 60 etc .when you put it on dry do you here water going in for 20 secounds :?:
