Hotpoint Aquarius WDL520 washer dryer blowing fuse
28 Aug 2009
Norfolk
Hi all,
Having trouble with my hotpoint washer dryer. When using the drying phase, the drum fills with water and blows the fuse in the plug.
The machine works fine on washing cycles.
My initial thought is that it is a faulty inlet valve allowing water into the drum?
Thought I would ask on here before opening it up to have a look, as someone may have more knowledge/experience, and be able to help.
Thanks in advance...
Cheers,
Just tried it again to be sure, and this time it tripped without any water entering the drum.
How difficult/costly is it to replace the dry element?
Unplug the two connections on the dryer then try. Just to comfirm it is the Element is about 15.00 on the web
Check its resistance with a multimeter. This meter will pay for itself almost immediately. Many members here will help you pick one.
