The second one only lasted a month! It was replaced when the engineer came to replace the motor and noticed that a previous 'engineer' had disconnected the suppressor. Having now fitted the third one he reckons if it goes again that we will just have to get a new machine!!!
Surely there must be some fault somewhere causing the suppressor to burn out?
All the connections look secure. One of the spade connectors was burnt out but both have been replaced. The main supply to the suppressor also looks secure.
