can anyone help me please. my hotpoint first edition 1000 not draining very well tried putting hose in bowl some water tricling out and also quite a lot of lime scale. any suggestions please
look at the back of mc .down the bottom is a square panel 6 screws remove screws, look underneath you will see a rubber cup with a jubilee cup round it remove it and that is the filter then clean it out .
thanks very much for your help. it took me six hours to do it but it finally works now. cleaned out the filter but it still trickled so removed the waste hose and it was clogged with limescale. put it all back together then the waste pipe started overflowing so cleaned that out too so now works perfectly. very proud of myself
