Hotpoint single fan assisted built in electric oven. fault code F01.
12 Apr 2008
Merseyside
The oven is showing a fault code F01, after about a minute of running.
All heating element resistances test OK.
I have replaced the temperature sensor probe with new but fault FO1 is returning.
Cheers.
Found this
F0 / F1. Stuck Touch pad. The touchpad or control panel, also called clock or ERC, is defective. This usually requires a replacement from a professional engineer if it cannot be cancelled out by itself.
