Neff Fan Oven - Fan Not Working
29 Oct 2014
Cambridgeshire
Morning All,
I usually post answers on Buildings and Building Regs but hope to find an answer to the following:
My Neff Fan Assisted Oven has started to develop an intermittent fault. Basically when you switch the fan oven on, there is usually a brief pause, then you here some relays click in and the fan and oven heater element then come on. Recently, the fan has sometimes failed to start up, resulting in a lot of smoke and then eventually after about a minute, it will start spinning and all is OK.
Sometimes when the relays click in, it sometimes changes the temperature at which you have set the fan oven to and you have to re-set it again (if you notice).
The oven is about 6 years old.
Any help would be much appreciated.
