Hotpoint Washer Dryer burning smell
Cheers Rocks1
I've got another question.
I thought the heater box housed the heater element for the dryer, but this one was empty. The model is a Hotpoint 860. I'm still trying to work out where the heat is produced???
Not sure, but does that model have the element around the circumference of the front of the drum?
no mod number 860 , do you mean wd860. if so heater box on top will split in two and the heater is there .
Hi there
This machine is now flashing F13 when it goes onto the dryer.
Can anybody help please?
heater box full of fluff and on the fan. did you clean it like i said last time
Hi Rocks1
Yes took the heater box lid off, and cleared the fluff. To be honest there was hardly any fluff in it.
check the fan is going round and clean the fluff filter at the back of the heater box ,a little plastic gauze thing.
Thanks so much for your help Rocks1.
The fan in the heater box had siezed up.
Replaced it today and it now works a treat.
My washer dryer has started showing F13 again.
I replaced the element a couple of weeks ago (it was open circuit).
There is no fluff in the heater box and the fan motor is working fine.
One thing i have noticed. Should the water valve be running constantly when the dryer is on. I took the grey pipe off that runs to the heater box and no water was coming out?
No it just spurts every now and then. Have you checked the themo cut out
