Hi, wonder if anybody can help, I have a Hotpoint washing machine (Ultima WMUD 962P) which suddenly stopped mid cycle and flashed up error code F5. So I googled this and after reading some tips, I took the bottom panel off and drained the machine of water and checked the filter (I did find 2 buttons), I also checked the outlet hose for any blockages, which there wasn't any. I then turned the machine on and attempted to put it on a rinse cycle but nothing happened and it just sounded like the pump out was kicking in. I then tried to put it on a new wash setting and then tried a spin cycle, but whatever setting I put it on, it just makes a noise like it is trying to drain.
Also I have tried putting 2L of water into the drum and running the spin cycle, and still the drum is not turning and the machine just makes a draining sound. Not sure what to try next - any ideas what the issue may be?
