The machine will not progress on to the spin cycle. Have checked the output pump and removed stray socks and coins and this part of the machine works fine, just no spin. Thanks
This is quite a common fault the brushes can be removed and replaced they should be no less than 5mm long.
I believe there are instructions to do this in this forum somewhere.
