Hotpoint WD62 Help
Status
Not open for further replies.
29 Apr 2005
Dear all,
I have a hotpoint WD62 washer/dryer.
Now I have the following problems..
1. Water is not pumping out.
2. Not spinning..!!!
Any expert comments are welcome..!!
:roll: Regards
your filter is blocked, its attached to the pump, but if you wait fido will tell you more
IS the pump blocked? try lowing the outlet hose into a bucket and check whether the water leaves the drum, once empty try seeing if it will spin again, if it works then you need to check the pump for either a blockage or failure.
b/b,
thanks a lot for your suggestion....!!!
also waiting for fido's guidence..!!!
+ can you tell me where is this located or any picture or so..and what i have do to?...
expecting ... :roll:
noddy
safest way, remove inlet and out let pipes, unplug m/c lay it on its back, pump is at back
Oh dear, am I becoming indispensable :roll: . You are probably best to do what Breezer suggests. You can take the back off but there are about a zillion screws for the back of the washer driers. There is not a proper filter but there is a trap fitted to the drum outlet hose. Look in there and also dismantle the pump to see if there is anything caught inside.
Thanks breezer/fido/babyxxxx for your help..!!!!
Great thankx once again...hats off....
:lol:
Status
