There are no flashing fault code lights but the problem seems to be in the bottom pcb...If I put it on a spin or empty program it starts making a clicking sound from the bottom pcb, in sequence with the clicking the drum will turn then stop, Same goes for the empty program whereas the pump will start and stop in sequence with the clicking...
Is there something I can replace on the pcb as it sounds like one of the solenoids has gone down or is it a new pcb needed.
Cheers Kev
Cheers Kev
