hi/ we have the above w,machine, and it starts of ok./ and does the wash mode/ but when it gets to the rinse prog it just stops.
it also does same thing when it gets to -final spin, .just stops.
lights come on ok/ as to what it should be doing.
i checked brushes they seem ok.
also while it was stopped i checked to see if the pump had power to it but it didnt.
but ive found out if i switch off and on again at the socket it then will carry on as normal and finish the wash. [ and pump will then power up ]
pump will work on the empty setting ok.
could it be the prog module gone lazy or somethink else , advice-help please. regards. r.r.
