Hotpoint WM52 door does not open
15 May 2007
Hi - washing machine blew plug fuse and tripped main fuses as well. Now appears to go through cycle ok but the door will not unlock. Not sure if this is because cycle is not finished or some other problem. Is there a way to unlock the door? Thanks
I would suspect the door interlock mechanism may have been the cause of the fault were it has gone short circuit initially therefore blowing fuse, mcb, or rcd and then going open circuit therefore leaving the interlock jammed on the lock position.
