Hotpoint WM63 washing machine leaking
27 Mar 2011
Fermanagh
My Hotpoint WM63 washing machine has started to leak. I have checked the door seal, using a couple of posts on this site, and it seems to be ok. Are their any other areas I should check? I have noticed that when on the spin cycle a little water leaks from the joint at the top of the drum, but this is only a small drip and would not be enough to leave the puddle I find after each wash.
You could check the dispenser hose drain hose drum seal that's the one between the front plate and drum.
