Hotpoint WM64 Buzzing?
6 Jan 2010
Suffolk
Hi
We recently aquired a Hotpoint Aquarius 1200 WM64 from freecycle - woohoo!
After a change of brushes its been fine, except it will NOT work on any of the very hot water settings eg C 95 degrees and D 60 degrees.
When set to any of these and then turned on, all that happens is a constant buzzing which seems to be coming from an area low down and towards the back on the left.
Although having inlets for both hot and cold water, we only have a cold water feed available and so this is the only one connected.
I've wondered whether this might have something to do with it.
Any ideas?
Cheers
Pentos
hot valve buzzing you need hot supply or a y piece to the cold .
