please can you help i have a rather aged wma 10 recently it has been unable to drain and will only do so by lowering the drain pipe into a bucket. when it tries to start to drain without the bucket method it makes a strange clicking noise which appears to be coming from the drain pump , i have stripped this part and found no blockage in either the pump or the in or out pipes but when turning the blades manually they seem to almost pulse 1/4 turn before some resistance is felt is this normal? i thought his may be a problem with the pump so i replaced it but the pump i have replaced it with is second hand and feels the same under manual turning is this one also deffective ? please can you help with some info as i am skint and would normaly be able to afford to just buy a new washing machine, but needs must i just need clean clothes!!!
please help
please help
