Hotpoint WMA35 washer - not spinning / not trying
16 Sep 2004
Leeds
Hi guys
We have a Hotpoint WMA35 washing machine. The drum is not spinning, there is not even a noice from motor as if it's trying to spin.
Basically, after selecting the desired programme, the drum fills with water, then the wash lights come on. Normally, the drum starts rotating at this point. Now, nothing. The lights are on but nothing is happening. No noise or anything.
Has the motor gone?
brushes gone in motor need replacment brushes
yes remove motor first ,2 13mm bolts and plug connector.inspect brushes first 3 types of brushes ,then search espares / masterpart /ebay for a good price.brushes are fitted to side of motor
Many thanks rocks1. Is the motor at the back of the drum or underneath it - i.e. Is it back off or bottom off?
back left of mc ,remove rear panel white with 3 screws and your in
rocks1, picture below of one of the brushes from the motor.
Isn't the spring loaded carbon rod normally alot longer than this, guess this ones very worn?
Do you know of any high street shops where I could buy a set of new brushes tomorrow, wife wants her washing machine back!! if not, guess i will have to buy of the internet and awit delivery.
Cheers
oh yes deff knacked brushes should be at least be a inch on there .any shops near you that sell whitegoods ,they will have them
just been on yell .com . appliance repairs leeds, it lists 26 for you to choose from :LOL:
Cheers, going to pick a set up today. Just one further question - the belt came off the drum when I removed the motor. Is it a case of trying to find the drum spindle and looping the belt back over. I only took off the small metal access panel to get to the motor.
yes loop it over motor first then over pulley you might find it quicker by useing a cable tie round pulley and the belt .then pull on to motor
Right, everything seems to be working fine, thank you very much. it was a right pain in the ass to get belt back on. The belt is not exactly centred on the drum pulley, it's more to the back and I think it's probably touching the drum. Will the belt centralize itself over time on the drum pulley? It's on a test wash now (empty) and it does sound as though the belt is rubbing!
just move the belt nearer to end of moter ,it should be 1 tooth from the end , moving it slighty by just pulling the belt over 1 tooth at a time
