I had an initial fault of F05 fault. I cleaned the pump out and dismantled hoses and fault clear but now the machine power button has no affect ( stays on) and the start/pause button has a slow flash. The machine will not start any program. there is no error code on the display and the program selector knob seems to change the program LED's correctly along with the time on the LED display.
To get to the hoses i turned the machine on its side and a small amount of water got onto the top control board. I dried the board off and remade all connections but still same fault. I was going to purchase a replacement board from e-bay but the seller suggests that it is more likely to be the lower control board to be at fault (this did not get wet). the connections of the top board do go to the lower board and this plug did get wet so may have shorted out.
Has anyone had any experience of control board faults on this machine. I don't want to end up buying the wrong control board.
Phil
Phil
