Just in time for Christmas, the mother-in-law's Hotpoint WT540P washing machine has started to make a "clunking" noise.
The washing machine is less than three years old and is used no more than 2-3 times a week.
I've only had chance to have a very quick look at/listen to it, so far and this is probably the best way that I can describe it ......
I put the empty machine on to 'slow spin' and as the drum began to turn there was a noise that sounded as though something heavy & metallic (like a bolt?) was being lifted between the inner and outer drums and then dropped to the bottom; the drum then span quietly at slow speed. This happened again when the drum had stopped spinning and then restarted.
As the drum built up speed, the noise level greatly increased and sounded similar to the noise you would expect if there was a pair of shoes banging about inside the drum.
There is no 'grating' noise, just 'clunking' and the machine does not appear to be vibrating excessively.
Any advice would be much appreciated, thank you.
