Hopefully you can offer your opinions on how best to deal with this please?
I'm ripping out an old bathroom to install a fresh one.
I've taken out the old bath and discovered that the heating flow and return currently run above floor level and used to be hidden by the bath panel.
I'm planning to move the bath so it won't be possible to do this with the new setup.
Picture:
The pipes go through the wall 6" above the level of the floorboards, so if I were to notch the joists and take them straight through the wall just under the floorboards, they'd end up in the room below.
I don't really want anything on show unless I absolutely have to, so the best option I can think of is to extend the 22mm pipe slightly, replace the pulled bend with two elbows and chase the pipes into the brickwork.
I know this isn't ideal, but with such a short run, will it cause any problems?
The wall will be finished in plaster at this point, not covered in tiles.
Thanks for any pointers or advice!
Picture:
