Hey all
Long story short. I've pulled up my kitchen floor and found most of it in reasonable shape except for this cross beam which is badly rotten. It was encased in damp dirt which explains things. The property was built in 1900 so perhaps this is inevitable.
There is a copper gas pipe right next to it which makes things tricky. Also the brick layer under the beam seems very brittle and I'm sure when I remove the rotten beam the wall will fall apart.
Given all this, my plan (already in action) is to concrete some bricks to the ground (see photos) and create a new foundation layer for the joists to rest on, using solids plastic shims (these) to get the right height. This obviously means the joists will not all be resting on the same beam (which i assume is helpful for stability). I guess I could add blocking/bridging between each joist to 'connect' them. They are all resting on the same beam at the other end of the room which is in good condition so im not touching that.
Is this a bad idea for any reason? I plan to treat the wood with anti rot and cover in DPC membrane before laying down onto the bricks/shims. So it's just about how to ensure a robust foundation layer for the joists to rest on.
