Hi
I have this little hook (about 4cm) with 4 nails in a wall and now need to remove it.
I have tried using tweezers/scissors to grasp the tiny amount of nails that are sticking out.
I have tried pulling the hook to see if the nails come with it... no luck so far and i'm worried if i pull TOO hard then it will break and make it harder (tho im not worried about the hook itself as i wont reuse it.)
Not sure if there is some trick out there to remove it? Suggestions appreciated!
