A TT supply, tails from meter into Henley Block supplying house CU (split with main S100mA and 30mA side) and single 30mA RCD. This single RCD supplies (via SWA) garage supply which is a normal garage CU (30mA RCD main switch with a 16A and a 6A MCB) The garage has its own earth rod and has a Ze of 64OHMS. The armour is earthed at the garage end. The client is adamant that the garage CU, which does have some nuisance tripping, (mixture of new and rather old wiring) is tripping the house CU (main 100mA RCD). I say this is unlikely as the only common element is the main tails from the meter. Is this likely?
