- Joined
- 3 Sep 2024
- Messages
- 6
- Reaction score
- 1
- Country
Hi. I have a large kayak that uses 3 parallel dense foam bolsters under the floor to make it easier to stand on. They are about 24" long, 8" high and 4" wide.
One of them tipped over. It was very difficult to remove it since space is tight. I applied soapy water and wet the interior. After a struggle it came out of the rear hatch.
Trying to get it back in is another matter. The bolster bottom and sides are flat while the top follows the contour of the deck. I spoke to the manufacturer (Jackson) who said that the boat expands and changes shape so it can be work to put it back in.
I was close to success, but there is a 2" elevated part at the top rear that has to pass under a dip in the hull. I could NOT muscle it through. So two possibilities...
1. Shave foam from the bottom to allow it to compress. This is my last resort.
2. I'd rather compress it somehow and the let it expand when in place. I only need to compress the 2" rise that is about 5" in long. How can I do that?
It will be work to get it out again so I need a good plan. Would an expanding car-jack make sense? Anything else?
