Hello! I have just bought a new radiator valve to replace my old one which is broken. (The TRV pin is stuck and I can move it both up and down with pliers but it does not spring back by itself even after lubing). I have actually bought a lockshied - I'm sure thats what it's called.
The actual changing of the valve is pretty basic I'm sure, just a case of unscrewing and screwing back on....however - I need to know about draining the radiators etc.
Do I have to drain them ALL!? And if so how do I do this? Is there one radiator that will have a draining tap and its just a case of opening this tap and draining it until nothing else comes out and then I can get to work replacing? Also...after the deed is done, do I then just refill them by turning the tap by my boiler until the boiler pressure shows normal?
Sorry for being such a damn novice! Thank youuuu
Extra note: In case it make a difference, I have a gas combi boiler.
