How do I choose a new combi bolier?
7 Jun 2014
Manchester
I'm in the market for a new combi boiler, how do I choose which make and model to go for?
I'm looking for at least a 7 or 10 year guarantee and around 30kw, I've a few plumbers coming round this week to quote but want a heads up before then, please give reasons for your suggestions.
Intergas ECO RF 30. The best combi on three market, only 4 moving parts (far fewer than any other combi, so less to go wrong), bulletproof heat exchanger design which has seen 20 years of service without a single failure, solid built-to-last all-metal construction, OpenTherm control confections for the most energy efficient controls available, and that all important 10 year warranty. What's not to like?
According to the manufacture website this only has a 5 year guarantee on parts, 10 years on the heat exchanger only.
Also as a comparison how many moving parts do other Combi boilers have?
Before you jump into a combi boiler consider your water requirements suit such. Just the one shower at the same time or two?
It's 10 years on everything. Have you got a link to where you read that please? Will let them know their website is wrong.
Other combi boilers have a diverter valve, diverter valve motor, and an air pressure switch as additional moving parts, as well as a second heat exchanger. They also run their pump wherever either hot water or heating is requested. The Intergas only runs the pump for heating, not hot water, which significantly reduces wear & tear
Find an installer qualified for your Intergas Heating boiler installation. ... Platinum Installer. Choose to have your boiler installed by an Intergas Platinum Installer and your warranty will be increased on our HRE and ECO RF range.
Which is but tough if you happen to live in Scarborough as the nearest Platimum appears to be in Middlesborough ( unless the list is out of date ).
Many of the "other combi boilers" do not have a massive slab of aluminium which has to be heated before any heat can reach the water flowing through the boiler.
