How do I get rid of air lock??
14 May 2007
Birmingham
Every time we turn the hot tap on in the house, there is a horrible noise (air lock) We do not have a tank in the loft - can somebody give us the procedure in getting rid of it!!
Cheers Ken
If you don't have a tank in the loft - is all your supply on the mains ? Combi boiler and mains cold. In this case it is unlikely to be an air-lock as mains pressure blasts its way through most problems.
Check also for loose pipes banging due to the pressure .
I have a combi boiler (vokera) its only on the hot tap that i have the problem my supply is direct from the mains - is there any quick fix ?
Ken
Dan_Robinson said:
You problem is water hammer - run a search on the forum,. but in the mean time try turning your main stop cock down a few turns.
Thanks for the input, although I thought water hammer is when you turn a tap off - my problem is when the hot water is in flow i.e shower or sink tap - this is when i get a horrible noise
Ken
You can get the pressure of the water rattling pipes during flow, esply if you have a loose washer somewhere, or a long run of unsupported pipe.
Just try turning the stop cock down to reuce the flow and see if it makes a difference. It's a start.
(Normally to clear bad airlocks, you use a mains pressure hose pipe so your problem is not an air-lock).
Ok, will try reducing the flow tomorrow
Cheers
ken :)
Dan_Robinson said:
I bet you haven't tried my idea?. :roll:
Is that the idea involving Kylie Minogue and a whole lot of whipped cream?
Cheers
ken :)
Still no good with this - I tried reducing the stop cock to almost zero and I am still getting a loud banging noise
Can anyone help with suggestions fixes
Ken
Not enough flow through boiler
dv problem
pump problem
scaled plate heat exchanger
