In another post I was told to isolate the boiler and do a full flow flush.
I have the pipes where a rad once hung, will these be OK for the flush if I swap the caps for valves?
Would this be OK to just screw hozelock fittings on and attach hosepipes then.
To isolate the boiler I presume I will need to put valves in the flow and return and a link between the f&r on the system side of these with a further valve and create circuits and isolate circuits with these. Do I isolate the pump as well (more difficult in my situation) or doesn't it matter which side of the pump I do this.
I'll use pushfit T's if the pro's think that OK with plastic barrier pipe for the link.
