- Joined
- 13 Oct 2022
- Messages
- 39
- Reaction score
- 2
- Country
We're redoing the bathroom. We have low pressure system (gravity fed vented), top of tank is about 1m above the shower head, 6 to 7L per minute flow rate (at the bathroom tap).
Currently we have just an electric shower (not power, no pump) cold water fed (15mm pipe from tank). Pressure isn't actually that bad, but it's a small head.
Since we're redoing the bathroom, replacing bath with a shower, girlfriend wants a dual bar mixer. Most of them say they need a high pressure system. We did stumble on this one (https://www.plumbworld.co.uk/mira-coda-pro-erd-thermostatic-bar-mixer-shower-3221-28238) that says it will work as low as 0.1bar but we do want a more powerful flow.
So I'm thinking about putting in a pump, but struggling to pick one. The pressure in the taps in the house are good enough so only need the pump for the shower, and enough positive pressure not to need a negative pressure one.
There's a lot of different pumps to choose from and many brands and big price ranges. Would I be fine with a 1.5 bar pump like this?
https://www.anchorpumps.com/niagara...-impeller-shower-pump-replaced-with-str2-1-5c
or
https://www.plumbworld.co.uk/salama...ugal-shower-bathroom-pump-rp50pt-1653-1253053
or is there a whole lot more to it?
Thanks.
or
Thanks.
