Pump for shower and bath taps?
14 Dec 2010
Hi
I'm installing a new bathroom that will have a twin impeller pump for the thermostatic shower/mixer/diverter. The hot water pressure is pretty lame (under .5 bar). I have found some bath taps that I like but they require 3 bar of pressure.
Is there any reason I could/should not feed both the bath and shower from the pump to boost hot and cold water pressure for both bath taps and the shower setup?
You can pump shower and bath supplies, you might have to change the pipework around as you don't want the toilet connected to it as you don't want the pump to kick in at 3am when your going for a pee.
Andy
