My Baxi Solo had a very noisy solenoid and it was getting slow to turn on the main burner. The fan, igniter and pilot work and although the pilot is lit, it keeps sparking and won't reach that last step. The problem is intermittent which tends to suggest the fault is not with the electronics.
The main gas valve was replaced (which on dissection shows it had a faulty seal) but the new one does not fix the basic fault. I asked the fitter how the flame is detected and he said something about an earth return. Well... electricity needs two conductors.
Can anybody expand on this? I also note there is a spark gap on the pcb. Does a spark jumping across it mean it is correct operation (ie, the interlock gets an ignition circuit working signal) or incorrect operation (ie, the interlock gets a spark voltage too high signal, which could happen if the spark wasn't reaching the chamber).
I am interested in explanation from someone willing to discuss matter of fact - at whatever technical level. Please do not reply if all you're going to say is to get the fitter back.
