How does halogen compare to conventional 60W
4 Dec 2006
Kent
Hi all.
I'de like to change my hall lighting from a single 60w conventional bulb to 6 x 50w halogen downlights. From a electric bill point of view will, this mean i will be burning 6 times the electrical power ??
hange it to a CFL easier, cheaper and if you like saves money
A watt of energy is a watt no matter how you use it, so 6x50w = 300w uses 5 times more than 1x60w=60w
TH lamps do provide a higher amount of lumens per watt though, but this is twinned with quite a directional light output (so you are forced to have quite a lot of them anyway)
recessed TH fittings are the woodchip wallpaper and polystyrene tiles of this decade though, avoid them!, nothing wrong with a normal pendant lamp holder in the hallway, and probably best to stick with a normal filament lamp in it as well, not a CFL (John will tell you different though!)
You hit the nail on the head! They are on the way out now.
Any idea what will be the next 'in' gimmick?
Bilmey never thought of them in that light (sorry .. bad pun i know :oops: ) ... definately dont want be lumbered with the equivalent of the above
Possibly back to drawing board then :cry:
I don't know where you heard that because in my experience 99% of the new build plans I see have either mains or SELV TH recessed lighting somewhere in the property
I'm not saying I agree with their over use but they are going to be around for a long time
One reason is a lot of modern properties have very low ceilings.
Not that I really care about fashion (as you could tell if you saw my clothes), but I have to agree with Pensdown - there is so much downlighting being put in new builds and as alterations that those who are against them seem to be in the minority.
If you are using 6 downlights instead of one 60W tungsten, then LEDs would be big enough. 6x 1.5 =9W. Instant switch on. Long life. and you could fit a PIR detector.
