Hi all, I'm new to this and wondered if someone can help. I have bought a Drayton RF1 wireless thermostat and tried to replace the wired one but I don't know what I'm doing.
This is what I know so far. The existing one has 3 wires connected - Neutral pin 1, Live pin 2 and a yellow cable to pin3. I have used a multimeter to find out that when the stat operates it makes pin 3 to 240V Live. This then connects to the valve which activates the C/H radiators. I plugged the RF1 wireless into the same backplate for same connections but the heating doesn't come on even though thermostat demands heat. I measured the voltage from the RF1 and found that pin 3 is about 30 to 50v AC relative to Live and Neutral but and this doesn't change whether the RF1 is on or off.
The thing I notice is that the instructions say it's a SPDT (voltage free) relay switch - what does this mean? Maybe I have the wrong stat for my system but I thought that if I replace with same name then it would be easy.
Any help appreciated.
Pete
Pete
