    Dismiss Notice
How easy to install a boiler?
Discussion in 'Plumbing and Central Heating' started by Scud14, 12 Jun 2011.
  1. Scud14
    Scud14
    18 Apr 2010
    53
    Thanks Received:
    2
    London
    Country:
    Hello guys...
    I know that most of you here are professional and have some knowledge about this issue.
    If there was a house with an old floor standing boiler and you wanted to install a new combi boiler but in another place inside the house because of size restriction for example.
    Will that be simple job?
    I don't know a bout plumbing but I imagine you will need to break the walls to connect to pipes and stuff....what would you do if the wall was covered with tiles?
    In general... how easy/hard is this job?
    I wish you share your experience with us.
    Cheers
  2. Sponsored Links
  3. 45yearsagasman
    45yearsagasman
    14 Mar 2010
    6,085
    Thanks Received:
    1,090
    Norfolk
    Country:
    I wonder why.....till now you have had 39 views but no replies except this one?
  4. cumbriahandyman
    cumbriahandyman
    23 Nov 2010
    1,256
    Thanks Received:
    43
    Country:
    Hi Scud,
    Afraid you won't get any help with this query. Basically what you are wanting to do is a no, no.
    You will need a gassafe chap or chapess
  5. muggles
    muggles
    28 Oct 2005
    12,412
    Thanks Received:
    2,719
    Daventry
    Country:
    Anything is achievable but without seeing the job it's hard to say whether it would be simple or not. However drilling though tiles is generally a bit tricky, but can be done with the right equipment.
  6. Sponsored Links
  7. Whitespirit66
    Whitespirit66
    15 Dec 2007
    8,012
    Thanks Received:
    755
    Bristol
    Country:
    Thought there was nothing wrong with the Mexico. ;)
  8. Scud14
    Scud14
    18 Apr 2010
    53
    Thanks Received:
    2
    London
    Country:
    I'm not planning to do that myself. But I was just curious about the job and how can installers know where the pipes pass inside the wall...etc.
  9. RigidRaider
    RigidRaider
    9 Aug 2006
    1,727
    Thanks Received:
    68
    Lancashire
    Country:
    I understand why you are asking the question and as I'm not a backside-covering plumber I don't mind giving you the benefit of my limited experience. We had a new boiler fitted a couple of years ago and yes, it was an expensive job because Mrs RR wanted it wall mounted quite some distance away from the old floor location and we wanted some modifications to the major pipework that supplied the heating and the hot water cylinder so we paid around £2000 for the new boiler and the modifications.
    With regard to going through walls, everything is possible but if the room is tiled there will inevitably be some damage, which a good plumber might be able to disguise.
    Your best bet is to invite three plumbers to quote for the job. Each will have different ideas about how it should be done. You shouldn't choose the cheapest but the one who has the clearest grasp of the job and the most interest in it. My advice would also be to look around for a long-established family plumbing firm, but that's just my preference.
  10. Agile
    Agile
    26 Jun 2004
    63,619
    Thanks Received:
    4,530
    London
    Country:
    Its usually pretty easy to work out where pipes are in walls in relation to drilling.
    To be sure as cables dont always follow the correct rules using a metal/power detector is always a good idea!
    Generally drilling small holes in tiles is not a big problem and even pipe sized holes are not a big problem with diamond tipped drills.
    Tony
  11. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
