G
Goldspoon
I understand the concept of gravity circulation to heat a cylinder (heated water loses density and hence rises up through cooler water).
If the upstairs radiator circuit t's off of the gravity circuit from near to the upstairs located cylinder then obviously the pipework is more horizontal. A pump is fitted to drive water around this circuit when the cylinder is satisfied.
Without this pump I believe I am right in saying that these upstairs radiators get hot gradually. If yes then is this caused by the flow initiated by the gravity circuit or is it caused by convection? Or both? Does it usually just extend to one or two rads or can it do quite a few?
With a pump (but not switched on) would the upstairs rads get hot eventually (i.e. can whatever is happening get past the pump?)?
