New ground floor ceiling job, will probably use standard 12mm sq edge (voids have 100mm soundproofing Rockwool).
It wasn't possible to put put some outer joists immediately adjacent the wall but I got them fairly close. I could always add some 38x38 CLS brothers along joist btm edges to take them closer to the wall. The wall will be wet plastered.
Is there a max that a ceiling plasterboard should float out unsupported?
Thank you.
Thank you.
