    Dismiss Notice
How far does heat travel on Soldered joint.
Discussion in 'Plumbing and Central Heating' started by renishawphil, 10 Apr 2019.
  1. renishawphil
    renishawphil
    18 Feb 2015
    76
    Thanks Received:
    Sheffield
    Country:
    Hi
    I am looking at using some fittings on central heating but will need some Soldered joints above the floor boards, can anyone advise me how far down the pipe it will get hot (i am not doing the soldering) before it could be a risk to a speedfit fitting,
    I have 3.5 inches between where the joint is going to be done and the speed fit fitting, thinking can put old very cold wet rags below where the joint is being done and the speedfit elbow to keep the pipe for getting to hot
  2. pete50
    pete50
    19 Mar 2017
    483
    Thanks Received:
    93
    Country:
    Surely the pipe that you are soldering will not have any water in it because pipes with water in them are virtually impossible to solder properly. Asssuming the pipe is empty can you remove the speedfit fitting? Heat does travel quite a way in a copper pipe so I would think the sealing O rings in the speedfit would be at risk at least.
  3. Gasguru
    Gasguru
    9 Sep 2005
    9,719
    Thanks Received:
    2,274
    Sussex
    Country:
    Wrap a wet dishcloth around the pipe...you can then solder with a very short distance.
  4. renishawphil
    renishawphil
    18 Feb 2015
    76
    Thanks Received:
    Sheffield
    Country:
    Would 3 inches be ok . I was think cold very wet clothes around pipe would work maybe even some ice cubes for good measure.
    How long does it normally take to solder a joint?
  5. ianmcd
    ianmcd
    15 Aug 2010
    10,260
    Thanks Received:
    2,858
    Lanarkshire
    Country:
    Another thing to consider , make sure that the flux while soldering does not run into the speedfit fitting, it will rot the grab ring and the fitting will fail
  6. renishawphil
    renishawphil
    18 Feb 2015
    76
    Thanks Received:
    Sheffield
    Country:
    Thanks. What would be the best thing to stop this for happening ? Wrap something round the pipe to stop the downward flow of the flux?
  7. JohnD
    JohnD
    15 Nov 2005
    56,823
    Thanks Received:
    2,891
    21st Century
    Country:
    Cook Islands
    if you have a speedfit, why not take the pipe out of it and do the soldering separately?
  8. renishawphil
    renishawphil
    18 Feb 2015
    76
    Thanks Received:
    Sheffield
    Country:
    I guess because of the access as having bathroom done, with a new radiator being hung and floor done. I guess could if really had to but not sure how feasible. If cant solder it safely then could possibly change to compression fitting ,
    If 3 inches is to close then I'll do it but if on other hand can be kept cool then I wont
  9. Gasguru
    Gasguru
    9 Sep 2005
    9,719
    Thanks Received:
    2,274
    Sussex
    Country:
    Yes 3 inches distance should be fine...assuming you solder fast with a decent blowlamp.
  10. renishawphil
    renishawphil
    18 Feb 2015
    76
    Thanks Received:
    Sheffield
    Country:
    I've read the John guest tech spec n it says 450 mm distance between plastic fittings and soldering so I am just going to take boards up and do in compression. Should have done that in first place. Better safe then sorry
  11. ianmcd
    ianmcd
    15 Aug 2010
    10,260
    Thanks Received:
    2,858
    Lanarkshire
    Country:
    yes and make sure all the flux is wiped off after the soldering is finished
    • Like Like x 1
Loading...
Share This Page
